Help Nexus 7 digitizer
leftnut26
I just bought 2 nexus 7s with cracked digitizers. hope it was good deal. Got them for 110. Both still function. So I found a new screen. My question is, are the screens on the v1 and the v2 identical? The guy said they were the same. Im just lookn for 2nd opnion before I buy
Don't know who "the guy" is, but you been lied to.
Ya I fugured they would be different. But I saw the side by side it shows the difference in resolution. But it also says they both use the same LED-backlit IPS LCD screen technology.
Are they both 2012's? If so, I bought screens/digitizers from Gadgetfix on eBay for around $65.
The size of the 2012 is wider and shorter than the 2013, too, so the screens physically won't fit on a 2013.
there are both 2012. i used that guy before i think to get some parts for an ipod or some other phone. thanks so much for the info. ill check it out. ya the one that i found is bulls*it. measurement for his are like 7.56in. sounded a lil big. he wont even give me a strate answer. just refers me to a link to the ad or says it fits both. lame. off to ebay i go!
