Have you unlocked your bootloader? Because you need that to flash factory images, and that wipes data. But if its already unlocked then you can flash without wiping.Nope to to my knowledge on disabling updates..
Yeah but flashing manually I will need to start over with all my apps (and a couple games too) since I am not rooted. Unless there is another option..
Anytime.So I side loaded 5.0.2 then 5.1 then 5.1.1 so fr it seems snappy like 4.4.4 I also noticed my battery does not drain as fast.. (so far)
thanks for the help
