Help Nexus 7 Music.
Hi guys I dont really know how to put music from windows media player onto my nexus 7, so far I have managed to get the album I want onto my google play music library, and im now stuck on how to get it onto my nexus from there.
Any help?
Cheers
If they got uploaded ok, all you should do is open the music app on your nexus and they should show up (given you have a working network connection).
As long as you are signed into the same google account on the phone it should just appear in the music app. When in the music app you might have to select all music in a drop down next to the headphone icon or hit the 3 dots (top right) and go to settings and do a manual refresh from server. Once its showing up you can then either stream it or download it to your device.
There are many ways to get music on your phone.
What I do is plug it into my pc. You access it like any flash drive.
You will see the internal memory folders of the n7. Drag and drop your music from pc to music folder on the n7. Funny at the begining of each drag and drop you get a warning that the music is not supported and will not play. It does.
I also use power amp as my music player. I can't see using data to play music. Even though you can choose on device music in the embedded Google Play music player
+1 - I do it the same way. It is the fastest especially if you want to transfer a lot of files. I do this also for videos where speed counts even more.
Suggest you encode your music in .mp3 and your videos in .mp4. For filetype conversion, use this program: Format Factory Home Page - Free media file format converter
And here is a little tutorial I made on how to handle this program: https://vimeo.com/9283805
