Root nexus 7 ROM like JBSourcery for galaxy nexus?
DannyJSlone
I have been searching all over for this. I just got a WiFi only nexus 7 tablet and I am wondering if there are any ROMs out there that compare to JBSourcery for my Galaxy Nexus. I love all the options it has and have been trying to find a good ROM like it. Thanks.
isnt jbsourcery for the galaxy nexus? i havent seen it for the N7... or are you looking for it on the N7? im confused
EDIT: i reread it and no i dont think theres a similar rom but you can try out Paranoid Android... it has lots of diferent features that are pretty cool.
I downloaded the one with 02-10 in its filename and attempted to open on my computer but it failed so I'm redownloading
EDIT: Was able to open the redownloaded one
I went back to stock, didn't have a non corrupted gapps at the time. I do now though
I have been running that jbsourcery build on my nexus7 for about a month now. It runs great! I don't think I've run into any issues so far. Definitely the best ROM I've had on the nexus 7! Definitely give it a try
Soooo, how is it? :D
Fantastic! Flashed the 3-3 rom w/03-01 gapps & Franco r48 for tablet. WiFi wouldn't work at first. Set up to static IP address & and now using Sourcerized Nexus 7!
OMG. Quick, smooth so far. Customization Nirvana! Now my DD.
I tried it and liked it, however, Youtube wouldn't play any videos. I restored my Paranoid backup and everything was fine once again.
I can possibly shed a little light here. I went from stock 4.2.2 to the JBSourcery V5. 0 (Test)(Pio's 3-3 OTA source) with a factory reset. Like you, I found that YouTube videos would not play. I went back to stock and then flashed Pio's Sourcery Grouper -02-10 with 20121212 gapps with factory reset. The YouTube videos play in that version just fine. It is Sourcery 4.5 which is a 4.2.1 rom but it works!!
Now I know some guys on one of the forums that have sourcery 5.0 and say the YouTube works. I will try to find exactly the path they took and then get back here. Meanwhile try the 02-10 build and see if the YouTube now works for you.
