Nexus 7 use while charging
  • Start date Start date
A
Android Question
Guest
Hi there!
I just bought a new Nexus 7 (I guess it's the 2013 Version, 'cause it was built Jan 13 - but it doesn't say anywhere - it was in a gray-black box). In the description it says that you cannot acutually use it while charging via the USB Port on a computer, which is weird, as I'd tried and it works just fine.
However I cannot find anything saying if it should work or not while charging via a socket. When I am using the charger that was delivered with it on a normal socket (Europe - 220V), the touchpad suddenly goes crazy. While I'm not touching anything, it's fine, but when I try to type or select something it just gets all jittery (e.g. touching the delete button, it may give me back some new text like "wetroritwp" instead of just deleting the last character). Does anybody have the same Problem or do you know if you simply can't use it then? (which would be pretty sad - considering how fast the battery goes and how long it takes to re-charge). I am just wondering whether I should return the device and replace or if a replacement would have the same issue...
Thanks for your help!
