I aim to buy a tablet shortly but am unsure as to get Kindle Fire hd or Nexus 7 16gb.As experienced users are out there who have likely used both & maybe even iPad mobile,which is probably ruled out for me because of cost, I would be very grateful for their views.![]()
On your PC, you use Google Music Manager to sync your PC music folder with Google Music in "the cloud". For pictures and videos, you run Picasa on your PC to sync/upload photos and videos to PicasaWeb in "the cloud".1) The Ipad has Itunes - what software does the Nexus have for PC as well to upload music/video and pics?
BOTH Apple and Google have the same issues. 98% of their apps work great on their phones AND tablets. 2% have issues with running on tablets. Usually if the app is popular, the developer will eventually correct the issue and get it working for tablets too. I would not worry about compatibility. Most issues for android tablet users are with tablets stuck on older versions of android (pre-honeycomb).2) I keep reading a comparison between Kindle/Nexus/Ipad - I know the Ipad has endless of apps on their store. I know google play has loads of apps as well, how many of them are catered for the actual Nexus 7, is there anyway to check the app store to see what is compatible?
