Help Nexus 7 wallpaper bug?
fenofonts
Hi all, I am having a problem with the wallpapers on the nexus 7.
Live wallpapers are fine, but static wallpapers appear scaled down, occupying the top 2/3 of my screen only. Updating to 4.1.2 and 4.2 didn't fix. Disabling scrolling, using wizardrii etc didn't fix either.
Am I missing something?
Bug happens on nova launcher and the standard launcher also.
Thanks!!
That is very strange.
Have you tried a factory reset?
Does it do that for every static walpaper?
Have you tried reinstalling the factory image?
If the device is non-rooted there really aren't as many troubleshooting options.
I have not tried a factory reset. I was hoping there was a way of doing it without.
Yes, it happens for every static wallpaper, including any image I download.
Device not rooted.
Should I try a reset?
