Charged my nexus 7 overnight, unplugged it this morning and it wont turn on. Tried plugging it back in and nothing. It's two months old. Any help or solutions ?
Thanks
I have had to hold the power button on for about 30 secs to power up before, from memory just after running the battery very flat, luckily its only happened a couple of times.
Just hold it for about 3 seconds and then wait for it to boot up. If that doesn't work, bring it to an electronic expert they can most likely fix it. If they can't, I dont know
On a couple of occasions, I've had my Nexus go blank on me and not respond to anything. As above, holding the power button for ten seconds worked. Alternatively, perhaps I only really needed to hold the botton for 2-3 seconds (also as above )
first try... hold the power button for up to 30 sec
2nd ... charge it for a over 1 hour.. and then try first step again.
3rd... i have read where the battery cable inside gets loose. you can take of the back cover and check to make sure the power connector is on tight. search on youtube to how to open the back (not hard). then try 2nd and first steps again.
