Nexus 9250
lennydude
Android Expert
No doubt this has been asked a cabillion times............sorry but searched with no luck.
I am buying a GSM galaxy Nexus #9250 from the Google Play site. I need to get some screen protectors and a black hard case for it.
I looked on a few sites and on Ebay but keep getting confused.:confused: Google says the phone is thinner than the #515 VZW version so i should get a #9250 case. There are quite a few listings that say they are the same?:confused:
As far as the screen protector goes, it seems they are the same?:rolleyes:
Can anyone help with this?
Thanks so much and again, sorry for the post if it is a duplicate.
Lenny
Lenny
Can you not google the specs of each phone to find out? That is what I would do.
I bought a diztronic case. It says it fits both phones, and it fit my Google-play sourced phone just fine. And it came with a screen protector that also fit fine.
Ordered this case. Thanks very much for your help.................way more usefull than a "google search" :):)
Matte Back Black Rev. 3 TPU Case & SP for Galaxy Nexus
