[FONT=Tahoma, Arial, Helvetica, sans-serif]Hi guys,
Here is a new release of your favorite Cronos ROM for your Device. This time it has the first release of Cronos X included.
This is still WIP (Work In Progress) by me and Computerfreak so please dont go flaming us about features that are not included.
If you have a wish list of functions please use a proper Forum thread to post them so that we can have a look at it.
NOTE: DOES THE PHONE FEEL SLOW AFTER THE FIRST FLASH?
GO TO X SETTINGS, CPU SETTINGS AND CHANGE THE MINIMUM AND MAXIMUM SPEED TO YOUR DESIRED SPEED.
I HAVE HAD TO PUT A LOWISH DEFAULT THAT IS SAFE FOR EVERY DEVICE.
You have bugs to report? Please use: MantisBT
Note: Please reboot after any flash you do. This is very important.
How to flash Cronos Roms:
1. Wipe
2. Flash ROM
3. Boot to full ROM.
4. reboot to Recovery.
5. Flash Hot Fix (If any)
6. Boot to ROM.
7. Reboot to Recovery.
8. flash kernel (If any updates)
9. reboot to ROM.
10. Reboot to Recovery.
11. Flash GAPPS
12. Reboot.
Release Notes
[/FONT][FONT=Tahoma, Arial, Helvetica, sans-serif]21 July 2011 | Cronos Ginger X 1.7.1:
[/FONT]
[FONT=Tahoma, Arial, Helvetica, sans-serif]13 July 2011 | Cronos Ginger 1.7.0
[/FONT][FONT=Tahoma, Arial, Helvetica, sans-serif]08 June 2011 | Cronos Ginger 1.6.0
[/FONT]
09 April 2011 | Cronos Ginger 1.5.0
23 Mar 2011 | Cronos Ginger 1.4.0
20 Mar 2011 | Cronos Ginger 1.3.0
14 Mar 2011 | Cronos Ginger 1.2.0
12 Mar 2011 | Cronos Ginger 1.1.0
11 Mar 2011 | Cronos Ginger 1.1.0
07 Mar 2011 | Cronos Ginger 1.0.0
[/FONT][FONT=Tahoma, Arial, Helvetica, sans-serif]Cronos Official Mirrors: (Thanks to Bertol and NetGhost)
The Official Cronos Mirror • download CGXN1-1.7.1_.zip
[/FONT][FONT=Tahoma, Arial, Helvetica, sans-serif]MD5SUM: On download link system.[/FONT]
[FONT=Tahoma, Arial, Helvetica, sans-serif]Google APPS:
[/FONT][FONT=Tahoma, Arial, Helvetica, sans-serif]Download latest gapps:
[/FONT]The Official Cronos Android Mirror
[FONT=Tahoma, Arial, Helvetica, sans-serif]Enjoy![/FONT]
1. Wipe
2. Flash ROM
6. Boot to ROM.
9. reboot to ROM.
11. Flash GAPPS
12. Reboot.
Release Notes
[/FONT]
- Fixed: Android Battery Drain.
- Please recalibrate your battery.
- Please fully charge the battery to 100%.
- X Settings updated to version 0.0.3
- Font sizing will stay permanent.
- Fixed: ScreenStatus Scaling.
- Fixed 30tweak file, thanks bleep42.
- System should be a bit snappier.
- Added a new version string for X Settings Mod itself.
- Volume rocker wakeup port by ComputerFreak
- Enable/disable CRT on/off animationport by Feeyo/Computerfreak
- Added option to change the indicator color in the notification widget port by ComputerFreak
- Fixed some checkboxed incorrectly checked by default by ComputerFreak
- Fixed some incorrect text when selecting brightness mode by ComputerFreak
- First release of Cronos X.
- Settings have extended options.
- Font size options ported by ComputerFreak.
- Battery Percentage option added.
- Battery Percentage Bug, fixed by ComputerFreak.
- widget button FC on MDPI devices fixed by ComputeFreak.
- Improved Danish Translations by ComputerFreak.
- Extra animation option ported by ComputerFreak.
- small GUI changes by ComputerFreak.
- A few tweaks used with flags.
- Fully Removed CM Extra.
- Sources have been updated to latest AOSP.
- Source for external and hardware support updated to latest CM.
- libSqlite improvement.
- Added Call Delay tweak by jyxent.
- lowmemorykiller improvement (Again)
- Added a few tweaks from Juwe11.
- BatteryWipe on flash by Seo.
- And of course all the Cronos speed imrpovements Added.
[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Updated CM Extra to latest.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Updated to latest Sources. (AOSP + CM).
[/FONT] - [FONT=Tahoma, Arial, Helvetica, sans-serif]Added DSPManager.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Added ThemeChooser.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Added Notification Bar Widgets back.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Added WiFi Boost.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]DeOdexed Compile.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]2.6.38.8 Kernel optimized with my own ToolChain.
[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Support for Vector Maps.
[/FONT] - [FONT=Tahoma, Arial, Helvetica, sans-serif]Fixed corrupted boot animation.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]This is an update Patch ONLY (No wipes needed!)[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Fixed JNI Bug.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Cleaned a Bogus htc core framework permissions entry.
[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Fixed libwebcore exception.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Updated to latest Android 2.3.4 Sources.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Tweaked Build Environment.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Added new EVO kernel, compiled with my private optimized toolchain.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Changed kernel configuration to drain less battery.
[/FONT] - [FONT=Tahoma, Arial, Helvetica, sans-serif]Fixed SDCARD issue: Corrupting Filesystems.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Enabled Screen On and Off.
[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Tweak audio APIs for better [/FONT][FONT=Tahoma, Arial, Helvetica, sans-serif]compatibility.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Fixed draw texture when loadTexture() is called.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Performance of toHex() improved.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]sdcard improve insertion notification on Gingerbread.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Ninepatch tweaks for better interop
[/FONT] - [FONT=Tahoma, Arial, Helvetica, sans-serif]Switch to SkSafeUnref for better portability
[/FONT] - [FONT=Tahoma, Arial, Helvetica, sans-serif]Fixed Bogus WiFi Garbage in xml's from an old patch of mine.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Updated to latest AOSP Sources.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Better Bluetooth Support.[/FONT]
- [FONT=Tahoma, Arial, Helvetica, sans-serif]Lock home in mem included.[/FONT]
- Resampler optimization routines properly patch.
- TextView.setText memleak fixed.
- SW renderer of Stagefright move on to draw stage after the initialization.
- Fixed isValid() Software EGL Rendering seg fault.
- Default WiFi sleep policy added.
- Added sdcard tweaks. (2MB)
- Removed Default Camera.
- Removed Default Music Player.
- Added MIUI Camera.
- Added Latest Android Music Player.
- Changed some compile optimizations.
- Faster GUI Animations.
- Updated to latest CM Extra. (By CM Team)
- Integrated latest CM source updates. (By CM Team)
- Updated kernel to 2.6.37.4
- OOM Error encoding images.
- Fixed contact data updating.
- Fixed Launcher Menu (more) Replication Bug.
- Fixed Heavy Graphics Load System Crash. (Library Exception)
- Reverted back to normal HDPI Resolution.
- Gralloc Mem Leak Fix.
- Updated to latest source updates
- AccessibilityManagerService death notifications proper clean up.
- Removed dead store : core/java/android/os/BatteryStats.java Patch2.
- Improved shutdown speed.
- revert PIXEL_FORMAT_RGB_565 (By Nadlabak)
- Improved Camera preview format.
- Changed to a bit higher resolution.
- Faster GUI responsive
- Bug fixes of DRM framework
- Removed dead code with no other effect than consuming battery life.
- float values equality checks : core/java/android/webkit/WebView.java.
- frameworks/base: Fix for force close during rapid FF of cetain midi clips
- Runtime inclusion of services in the SystemServer with overlays
- Fixed memory leak in PreferenceScreen.
- Removed strict lowmemorykiller configuration.
- Should be nicer to battery life.
- Updated to latest Sources.
- Fixed Memory Leak.
- changed some Kernel configurations.
- Fixed Volume Key handling. (nadlabak)
- Patched libfreetype for better rendering of fonts.
- Changed animation speeds to be a bit slower. (Nicer to look at)
- Smoother GUI.
- Fixed coma no wake issue.
- Fixed low memory bug.
- Updated kernel with BFS.
- Updated Sources to latest version.
- Fixed USB.
- Included Performance Kernel.
- Fresh full clean Sources (Again..)
- Fixed Battery Icon
- Fixed WiFi/3G Bug.
- Unlocked Android 2.3 Audio effects for Music Player.
- Removed DSPManager.
- CM Extra updated to latest version.
