Slightly different from the reported 3G issue guys (but maybe related).
On my N1 I notice consistently that the signal drops when the phone is picked up, and specifically if my hand is wrapped around the bottom of the phone.
Whilst not a deal breaker, this can be annoying in weak signal areas when starting a text with only 2 or 3 bars of GPRS signal can result in no signal shortly after.
Also, has anyone noticed that if you send a text when you have no signal, it will not send once the signal has been picked back up? A small software glitch I think.
This happens slightly less with calls where the phone seems to maintain a signal when connected even if holding the phone naturally (near the base).
So, is it:
Weak radio?
Software glitch?
Poor design too install the antenna at the base of the phone?
All of the above!!?
Your thoughts please...
So, is it:
Weak radio?
Software glitch?
All of the above!!?
