jranderson99
Hi all for those of you who have been having problems with free USB tethering or hotspots first make sure you are running 2.3.4 this should be before the update then in settings you need to select tethering or activate hotspot it will not do it automatically I. Haven't had any problems just make sure you don't update cause then you'll lose it for free hope this helps
