NFC Icon missing and Palm Swipe capture is not functioning
Hi guys, I just got my S7 Edge last week, after 1 week usage, I release that the NFC icon is missing eventhough NFC is switched on, and Palm Swipe Capture is not functioning, but Power Button + Home button is working fine.
Any idea how to fix these 2 problems? :(
9 icons
I know with my S7 I had an Otterbox case on it and it made the hand gesture near impossible because it covered the edge of the screen. The Spigen case I got doesn't cause the same issue. .. Not sure if this is the case with you or not.
