psybab Member Jul 2, 2012 #1 Does anyone know if leaving the NFC/S-Beam options on all the time significantly affects battery life?
J jerofld Fixing stuff is not easy Jul 2, 2012 #2 I doubt it, as it's a low power transceiver. I would just disable it for security purposes, unless you regularly use NFC/S-Beam.
