NFC Tags or Tasker or??
-=Jeff=-
Android Expert
SO now that I have my MAXX, I am not sure I want to root it yet so I am using my old RAZR MAXX in my car for my APP Radio. so if I want data in my car I need to WiFi hotspot my Maxx. So is there a simple way to automate turning WiFi Hot spot on? maybe it is using a tag and tasker to automate the task?
looking for opinions
Tasker Is what you want to use. I have used is ever Smart Actions was let go. There is a bit of a learning to use it, but once you get the hang of it is just fine
Right, I use tasker on my old Maxx for App radio connections.
So is there a way to automate the task once created, like use a NFC tag to trigger the Tasker Task?
I've been having great success using Condi (Previously Mini Tasker)
You can have it turn on/off bluetooth and open an app when the GPS senses you're driving. You can also have it turn things on or launch apps when plugged in. I connect my phone to a charger in the car (keep in mind I have the Mini, I am envious of your batteries) so, I have it automatically turn on Bluetooth when charging.
Ok, with the caveat that I haven't tried this app, for NFC tag type settings changes, this app NFC Task Launcher has good reviews: https://play.google.com/store/apps/details?id=com.jwsoft.nfcactionlauncher
Otherwise, there is tasker, which I know can kick off activities based on how fast you are traveling. However, you may not want that - if you are a passenger in somebody else's car, you may not want to have the hotspot toggle on. That's why NFC tags may be better - you can have two in your car; one to toggle hotspot on, one to toggle it off. (If that app NFC Task Launcher can toggle hotspot...)
Couldn't you have a NFC tag be detected by the phone and have tasked run a task on the detected tag?
Guess I need to buy some tags and try it
