Help NO 3G (Edge Only) on Roger's Network in Canada
EZ44
Hello,
I have tried a few of Roger's APN's including internet.com and rogers-core-appl1.apn but have yet to see a 3G connection on my phone. So far it's been on constant 'Edge' or on a rare occasion 'GPRS'. I have taken it out with me while running errands around town but it has never connected at 3G speeds. I never had a problem with any of my iPhones getting 3G speeds. If anyone can help I would greatly appreciate it. So far I have tried 'Network Mode' on 'GSM only' and 'GSM/ WCDMA Auto' but it made no difference. Listed below are the 2 APN's I have used on the Roger's network.
APN: rogers-core-appl1.apn
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
MMSC: http://mms.gprs.rogers.com
MMS proxy: 10.128.1.69
MMS port: 80
MCC: 302
MNC: 720
APN Type: Default
APN: internet.com
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
MMSC: not set
MMS proxy: not set
MMS port: not set
MCC: 302
MNC: 720
APN Type: Default
Thank you for any help or suggestions that you may have.
:confused:
Where did you get the device and what bands is it using? I suspect you have a device that doesn't support your network.
I see from another forum you figured out you have a T-Mobile Streak. You should be able to just resale it, they are rare :D
Was just going to say that my streak on rogers works fine. It works great as a replacement to my archos tablet but i miss my galaxy s!
