Same problem, is it playfulgod's cm7.2 rom, or another one? I had cm6 running, and it worked perfectly(SDK, Eclipse,command promp), switched to cm7.2, now every time I plug my phone up, my computer wants to install my phone?? Nothing was changed with my computer setup, and the regular mounting works, no adb interface, just android mobile adapter(with yellow ? mark), and Android Adapter USB Interface, in the disk drives section. Downloaded every Usb driver I could find, deleted all, but one, rinse , repeat, no luck. Changed usb files, put the huawei id"s in, damm, no luck. Went into the build_prop file, added info, damm. I'm using XP32 bit, if the rom didn't make my phone run so good, I would have reverted back to cm6.
