no android market
Hello and welcome aboard. :)
I'm quite sure that you'll find it in your app drawer. The drawer that has all your installed and preinstalled applications. Google has change the name of the Android market to Google Play Store - so keep this in mind when searching for it.
If for any reason you cannot find it, here is a download for the market. Google Play Store v3.5.16 Vending-3.5.16.apk. Note: This can be installed using your device. You might have to press install more than once if the first time fails.
Best of luck. Also, you might wanna check in to your device's support forum for some awesome tips, hints, and info on your device. Just choose your device model from the list here on the home-page.
