Help No boot load screen
Etwizzy
Member
I tried to use a program that changes your boot load screen. In turn I deleted my stock boot loader and now every time my phone turns on all I see is Samsung a little yellow triangle with an explanation point. After that my screen goes black. I need away to get back my stock boot loader please.
From my experience, none of those apps work on our Rush
You should find the bootanimation.zip that the app installed in either /data/local or /system/media
Rename it to bootanimation.zip.bak and restart
If that gets you back to the stock animation you know you can delete it ;)
Idk where the app saved to. Once the boot loader started acting funny I deleted the app
OR - If you can remember which app it was I'm willing to do exactly what you did so I can walk you through getting your phone back to the normal boot animation.
Thanks you are a God send the app is boot animation changer. I used this app on my prevail and it worked just fine. Since the rush its also called the prevail2 I didn't think it would cause so many problems.
So what did you do when this happened?
I think I did the fix option honestly I can't remember. I may have tried the second thinking it would install a folder so I would have a go to place.......... Yeah that button looks familiar:confused:
These instructions are going under the fairly safe assumption that you are rooted, as you wouldn't have messed up your animation with said app if you weren't.
The app in question puts its animation into /data/local unless you directed it to put it somewhere else.
Ok here we go;
If you don't yet have one, install a file explorer that gives you root access.
Root Browser is free and will work for what we're doing - https://play.google.com/store/apps/...yLDEsImNvbS5qcnVtbXkucm9vdC5icm93c2VyZnJlZSJd
Open Root Browser and navigate to the location /data/local
Grant root access when it prompts you
In the location /data/local you should see a file named bootanimation.zip
Delete bootanimation.zip
Reboot and you should have the normal animation
If not I would need to know exactly what you did step by step
Ok here we go;
I did what you said sadly it didn't bring back my boot animation. I hit the button to create another download location. I think I screwed up by letting it overwrite my old location
If you pressed the Apply location button without typing anything into the field then do this -
Navigate to /data/media/
There you will find a folder name bootanims
Delete that folder and see if that does it
I tried that too. No go. Smh this is what I get for not asking the professionals. I know life is about trial and error but damn this is crazy.
