Help No carrier name & call log problem
Rumon
Stock rom not keep my call record in call log. Also no carrier name in Status-bar & lock screen its only show services disable how can i fix that? can any one help me.
First are you rooted with recovery installed. Or just stock alone? Either way it sounds like you need to factory reset. For those rooted with recovery installed. They can reboot to recovery then do a complete wipe minus external sd. Then reinstall stock rom,reboot and go to settings,system updates and update the prl and profile. Should be fine. Or if stock unroited,these users can do a factory reset via system,backup and reset. You can always try clearing the data on contacts and LGTeleservice apps as well.
Thanks Curits, But the problem still persists. Its not logging my call history.
And lock screen carrier label still show services disable.
Ok. Well I assume you do actually have service with a carrier. Which carrier are you with by chance? I will try to help figure out what the issue is.
I have a Volt on RingPlus in the United States, and it has never showed the carrier name on the screen, only LG. It doesn't affect the actual service.
If the stick calling app isn't logging your calls, have you looked for a third party app that might be able to do it? There are probably several that you can try.
Hi Rumon. If you have flashed any of our roms that may be your issue. Your Volt would be an international model I assume. If you have flashed any of our roms you could be having apn issues because of it or various other issues as well. The best advice I could give would be to visit LG website and see if a image of your particular device and service is their for you to flash using the lg tool kit. Outside of that I cant offer much further assistance.
I'm on Verizon in the USA and my phone never displays the carrier's name UNLESS it is Verizon.
Generally speaking, not have the carrier name displayed won't affect anything. Most of our phones lost the carrier name when flashing the stock tot file before was had other root methods and it still worked fine... does it display absolutely nothing, or does it say LG where the carrier name should be?
Also, is this a new development?
A few devices give you a choice
...carrier logo...
...or carrier name...
...it is Android Lollipop 5.1.1 and not iOS 6. :)
or can have nothing at all, just the signal indicator, this is Oppo or Vivo. Chinese phones and I'm in China. :thumbsupdroid:
Hi, Curtis. Thanks for your email. No my Volt is LS740 Sprint i purchase the phone from best buy USA. i get this stuff from my relative. And just for Ref./ there is no international rom for Volt LS740. You can help me if u have this devices please activate with sprint and give me the twrp backup.
Exactly this is happen to me
