no connection?
ok so i wen i go 2 tha android market it says loading then like 1 second later it says "a network error has occurd" it says tha same wen i try n log in2 facebook and browse the internet? is this like an apn problem or sum shit, if it is how do i fix it?
Well to start are you using a wireless connection or a data connection? If it's wireless are you connected to free wireless or if a password is needed have you typed in correctly. If it's data - you'll need to confirm that your apn is set up. Settings> Wireless & Networks> Mobile Networks> Access Point Names... if after that you see a blank screen, you'll need to google your network provider and input the apn settings via the soft menu key. If you have settings already there - do you have credit? have you tried restarting?
