no data connection
  • Start date Start date
A
Android Question
Guest
Have had orange get me back on mobile data 3 times now. It only lasts a few hrs then I'm unable to get onto mobile data again. I have s3galaxy gr8. Fed up with it now. Can anyone help please with a cause for this prob!!!!!
Try to find out what they do to get you back on data. If it's reprovisioning your account, they're mucking things up on their end. If it's resetting your APN, the question is why it has to be reset all the time. (A runaway app can change it, or the phone could be defective.)
The first step in fixing a problem is finding out what the problem is. So far we only have the symptoms.
