Help No data - UK Vodafone N1
hunta
My N1's been working perfectly since I bought it from Google in January... until today.
I have a good signal and can make / receive voice calls and texts. However, I'm not getting any data and no 3G / 2G etc. icon is showing on the bar next to the signal strength icon. I've tried going in and out of airplane mode, going to 2G only, rebooting, removing battery and reseating the SIM and SD cards.
Vodafone have confirmed there's no issue on their side (other Vodafone users nearby have aren't having problems) and have even swapped my SIM with no effect. I phoned the HTC help line (very quick and helpful BTW), who tried setting up a new manually defined APN. Nothing's worked.
Next step is to try a factory reset, but before I do, any suggestions? (This is under 2.1, ERE27.)
As you're on ERE27, give FRF85B a try, can't hurt.
You've not done anything silly like installed APNDroid and accidentally disabled data have you?
Try hitting reset to default in Access point Names by going into it and pressing the menu hard key on the bottom of the screen, this worked for me on o2.
Thanks for the responses.
I decided not to upgrade manually to FroYo. I wanted to keep the number of variables as low as possible, plus if it was going to come down to sending the phone to HTC I didn't want any question marks at all over the warranty.
A factory reset cured the problem. Unfortunately though I didn't see justdoit's tip before I did it!
