no devices
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
What phone do you have ?
i am trying to install inspectorade on my phone ,but am getting error message
"i have no devices'?
Welcome to Android Forums. Unfortunately, if you can't install a certain application from the Google Play Store onto your device, chances are that the application isn't compatible with your device. However, if you had already installed said application then uninstall _ you might have other problems going on with your device.
Try to install this: https://play.google.com/store/apps/details?id=com.inspectorade.android. If you are still getting the same error...you might not be able to get it onto the device.
