Help No Display Problem Can Anyone Help Please ???
Asko
my xt890 lcd screen and digitizer were broken so i changed them and the phone was working fine for a week, i then wanted to update to kitkat through oem update; everytime i tried it would give me error . i then read that since i unlocked bootloader and rooted my phone and installed cwm recovery i couldnt do an oem update and i had to do a factory reset in order to update through oem, so i did just that ; after the phone finished factory reset and booted i proceeded with oem update while the phone was charging, everything was going fine the file was downloading, i went to the bathroom and came back the display was black, but touch screen was working fine...through more searching i read that this could be from the update, and i should do another reset... since i couldnt see anything even recovery menu. i downloaded moborobo so i can see my screen on pc and proceeded to factory reset ... now i cant even see through moborobo and im stuck. i think im stuck in recovery screen, but no way to be sure , hence i cant get usb debug.Please help.
Never, ever take an OTA system update whilst rooted or using a custom recovery.
Do you have a backup in CWM you can restore from?
Can you get the stock firmware file for your device? I suspect you'll need to flash that to get things working again.
I can get the stock firmware but the problem is that there's no display now, and i am in recovery menu, so no usb debugging , plus i cant make any selections in recovery mode :-( :-( :-(
Sorry, I misread your post and thought the screen was working in recovery. :(
You're out of options unfortunately, it's most definitely a hardware issue so you're either going to need to replace the screen again or contact the manufacturer and ask them to do it.
