No GPS
cygnis1
Hello,
I accidentally turned off gps on my htc aria, and now I have no gps. The phone doesn't display my location. Navigator and Foursquare do not work. I tried to see if I could do something with the settings, but there is nothing to control gps. It is eitehr on or off.
Has anyone else had a similar problem? How do I fix it?
Thanks,
Cygnis1
add a gps widget to the home screen. Its under Settings-Gps when you long press the home screen to add a widget. Or you can manually turn it on by pressing Menu-Settings-Location.
I have the widget and gps is enabled,but does not work. The display shows "Current Location" and not the actual location.
I downloaded GPS test and it shows gps working. Foursquare works as does maps. However Navigator does not work.
