Help No more notification icons
PedroTibo
My kids sometime sneakily play with my phone while it's charging... This weekend I ended up with a rather strange icon and no more notification icons. Could not find any useful info on the web.
See reply post for image
Please help.
Hi PedroTibo
Yes, I had the same soon after I got this phone. It's merely telling you that your notification is turned off. It's an 'I' with a line through - ie 'no information'
So, pull down the notification area (not sure what it is called) so that you can see the buttons for turning on/off wifi, GPS, Sound, Screen Rot, Power Saving, Notification, and so forth.
Tap Notification button to turn it back on. You will see it light up again!
Hopefully, that should sort it ...
Cheers
