I don't know why last night's post never got posted, but I'll try to reconstruct it:
According to what I found when I checked my device last night, I have over 17GB empty on my new 32GB card, but it is inaccessible because the USB storage is COMPLETELY full. When I try to access USB storage on my device in order to clear it out, I get the message that it's empty.
Meanwhile, I can't download even a PDF file, let alone an e-book or a music file. The only things I can download are updates to the files I already have. When I try to move an app from the phone to the SD card, I get the message "SD card is full." Even tho it isn't. Why can't those Google programmers at least program Android to tell the truth?
I cannot use the stock music app because there's "not enough memory." For the same reason I can't open the gallery. I can listen to my music on Amazon MP3, but I'd rather not have to resort to that.
FBReader opens to the wrong books, but I don't know if that is related.
I regularly clear the cache, and I do what passes for optimizing RAM on Gemini, but it doesn't help one whit. I can't clear the cache on the stock browser.
The browser crashes several times a day. Sometimes the OS goes into a loop in which it reboots every few seconds.
The link that csrow recommended here:
>If you are on 2.3.5 ROM (not updated ROM), then you can flash a SWAP SD file to switch the Ext-SD with the internal SD.
>the SWAP SD file can be downloaded here. You will have to know how to flash a zip file from the recovery.
>Dev-Host - swapsd.01.zip - The Ultimate Free File Hosting / File Sharing Service
is no longer available.
I have uninstalled ALL the downloaded apps that I think I can do without even the apps that I'd rather have,, and I'm not updating the unremovable bloatware that I never use.
I fear that the only solution may be to restore factory settings, but how do I save my precious files and bookmarks? I have MyBackupPro and Dropbox (don't ask me why I have both, but I don't know which one will help me now so I'm not uninstalling either of them). I've tried to back up to MyBackupPro, but the big problem is music files. The backup process never completes for music, and when it stops the entire effort is wasted. Can I copy my music library to a flash drive and reinstall it on my SD card? Can I do that with ebooks too? (All my ebooks and music files are DRM-free.)
