no move to sd button
deb123
I bought a sony xperia e1 dual...and i wanted to move apps to external sd card without rooting it.Please help me....
Most apps can't run from the SD card, so you won't find the button. Apps like Link2SD will force move an app, but most apps won't work if you do that.
Consider the SD card a place to store media files, not a place to install apps.
I believe Google (stupidly) removed App2SD in Jellybean and onwards, so the only way (I think) is with root.
I know that with the old HTC Desire, you could force apps to install on the sd card using ADB (not root) but I doubt this would be possible for you device, although it's worth looking up
