As I said in my post there is NO Settings>lockscreen>lock screen type >noneGo to Settings - Lock Screen
After entering your PIN you can select "None" as an option to remove all security (I do NOT recommend this, but I don't know your circumstances).
You can also select another type of login. I have face unlock, fingerprint and (in case of emergency) the PIN.
There is no NONE option here to choose from (not even greyed out) which i have read other people are having the same issue but no solution has been found
Have you tried under Passwords & Security?As I said in my post there is NO Settings>lockscreen>lock screen type >none
Go to Security ---> Screen Lock ---> Swipe. Changing it to swipe removes the lock whether it be Pattern, PIN or Password.hi I have android 12 and i have a pin lock screen enabled. I want to remove it but when i go to lock screen and screen lock type i enter my pin and see no option to delete, remove or none?
There is no way to remove the pin setting?
