Just reflash the ROMHi everybody I have a huge issue now my zmax now boots to twrp and says there's no os installed?. All of my stuff as far as I can tell is on the hard drive I'm confused. How do I fix this?. I was on cm 12 r5. Any ideas? Any help would be appreciated. Thank you.
Anthony.
What twrp u using if its the newest go back to the old twrpIt gives me an error that says unable to mount system. What does that mean?. Any ideas?. Need help. Any help would be appreciated. Thank you.
Anthony.
Also nandroid backup once you get everything back and running.
I think they deleted both of your replies?. I'm not sure what you advised me other than nandroid backup. Can you repost please. Thank you all for the help.
Anthony.
I got it to work again by flashing stock b13. Problem is that now it won't root. King room temp root? . No idea how else. Any help would be appreciated. Thank you
Anthony.
Anthony.
i had this problem 2 i just wiped whole phone then cleared caches like 20092894757 times then flashed rom again and it finally workedHi everybody I have a huge issue now my zmax now boots to twrp and says there's no os installed?. All of my stuff as far as I can tell is on the hard drive I'm confused. How do I fix this?. I was on cm 12 r5. Any ideas? Any help would be appreciated. Thank you.
Anthony.
Anthony.
Did you flash the stock ROM and recovery or just the stock ROM by itself?
