I have had my Rezound since it first came out and up until Nov had no problem. Now when I try to connect to PC via USB, my computer does not see it. Have rebooted, pulled sim card, reloaded HTC sync to pc, reset all the debug and disk switches. Need some help here, please!!!
Have you tried a different USB cable? Have you tried connecting to a different PC?
Did anything change between November and now? (software updates to Sync?) If so, can you rollback to the software version that worked?
Roll-back firmware? You can't in the HTC without going S-OFF, and that is NOT a novice thing to do.Somewhat of a novice, how do I rollback to prior software version>
