No pinch zoom using Dolphin Mini Browser
Motorhomer
I've just bought a Samsung Galaxy G3 and cannot get pinch zoom using Dolphin Mini. Pinch zoom works fine in Gallery and GMail and it was fine on my G2 using the same browser.
The only place where it won't work is when browsing the web using Dolphin.
I've tried every possible setting but to no avail. Has anyone else experienced this problem?
I'm not sure which section to post this is as it may be a Dolphin problem or it could be related to the G3 so I'll post in both this and the G3 section.
Weird.
There is settings / Lab / Pinch-zoom button. You might try toggling that to see if any difference. Or at minimum, maybe you can use the button to do your zooming.
