androidb
I have been having a problem with push mail not working on the Razr. I set up a Google Apps email account, under "Accounts", "Email Accounts", "Other". Obviously I set the account to push, instead of fetch. Nothing.
Mail would not get pushed, it would come in sporadically, if at all.
I set the account up as IMAP and followed Google's settings:
Incoming settings
IMAP server: imap.gmail.com
Port: 993
Security type: SSL (always)
Outgoing settings
SMTP server: smtp.gmail.com
Port: 465
Well in searching for the problem, I came across a lot of other Razr owners on other sites having the same issue. I Found this link from Motorola: https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/73082/~/email-troubleshooting-%28no-email%29-%28droid-razr%29
I tried the first option, "if using secure connection, un check secure connection". Sure enough that did it! Even though Google says it should have SSL always, turning it off worked. Mail gets pushed to the device instantly, within a second of sending my test messages from my desktop.
I hope this may help anyone else who is having a problem. I'm sure turning off SSL would work for other types of accounts, not just Google.
**************UPDATE***********
After power cycling the phone, the email account threw errors that it couldn't connect to the IMAP server. I then had to enable SSL in the account settings and go through an email check. After the check, of course no push again. So I had to go back into the email settings and un check SSL and it worked again.
I don't now what is going on with this. I just upgraded to the Razr from a Droid Bionic. Used the same email setup on the Bionic and never had to do this. Push just worked from the beginning.
Port: 993
Outgoing settings
Port: 465
