Apps No resource identifier found for attribute 'apikey' in package android
I' m developing a simply gogglemap app and i'm having the following error in main.xml -> "No resource identifier found for attribute 'apikey' in package android".
I don't know what's wrong cause i've followed all steps of tutorial.
My files:
-----------------------------main.xml-----------------------------------
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
<com.google.android.maps.MapView
android:id="@+id/mapa"
android:layout_height="wrap_content"
android:clickable="true"
android:enabled="true"
android:apikey="0z_TI6zsLHOcJElkUTJIvmgQ_DRInwlYjUgu7Cw"/>
</LinearLayout>
-----------------------AndroidManifest.xml-------------------------------
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.android.exemplo.mapas"
android:versionCode="1"
android:versionName="1.0">
<application android:icon="@drawable/icon" android:label="@string/app_name">
<uses-library android:name="com.google.android.maps"/>
<activity android:name=".Mapas"
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
</application>
<uses-permission
android:name="android.permission.INTERNET">
</uses-permission>
<uses-permission
android:name="android.permission.ACCESS_FINE_LOCATION">
</uses-permission>
<uses-sdk android:minSdkVersion="8"
android:targetSdkVersion="8"
android:maxSdkVersion="8" />
</manifest>
----------------------------------Mapas.java--------------------------
package com.android.exemplo.mapas;
import com.google.android.maps.MapActivity;
import android.os.Bundle;
public class Mapas extends MapActivity {
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
protected boolean isRouteDisplayed(){
return false;
i'm using as Project build target the Android + Google API in -> Properties
Somebody help me??????:(
just clean your project. i did the same and it solved my problem. it happens because some files get damaged while creation..
Also, you need to make sure that your target SDK is "GoogleMaps APIs" for whatever SDK version you want. You can change this from the project properties in Eclipse.
