M Mel Calaby Lurker May 3, 2016 #1 Since upgrading to marshmallow 6.0.1 I have no ring volume and the control is greyed out in settings Moto g 2015
T txaspeat Member May 3, 2016 #2 can you not adjust it by pressing the volume key on the side then the little arrow next to the volume slider bar?
M Mel Calaby Lurker May 3, 2016 #3 txaspeat said: can you not adjust it by pressing the volume key on the side then the little arrow next to the volume slider bar? Click to expand... That was it, thanks. Never experienced that issue before.
