Hi,
One X
Just had the 4.1.1 update, all seemed to go smoothly,
However on Power/battery usage the is no "Screen" information
Main page is new & now split between apps & others
Apps: usual stuff...
HTC Sense being main %
Other usage:
WiFi
Phone Idle
These are the only 2 hardware things & no sign of screen anywhere.
Was always at top, especially being main draw.
No chart at top either
There is a chart & some info on the history screen but no detail & can't really see to a useful level.
Also noticed even after restart &/Or power off, seems to keep the history,
On "history" says been on battery 17 hours, not sure if this is because I have yet to charge back to 100% but would have thought a power off would have taken it back.
Side note, my Agenda widget on my home screen has just dissapearded, no big deal but never done that before? I definately did not accidently remove.
Not sure if attachment worked, if so the only thing that got cut off was the "phone idle" right at the bottom.
Pre JB had NOT been getting great battery so been investigating & quite pleased JB update as might clear out any problems & poss improvement but sees the opposite so far on my very limited testing.
One X
Other usage:
WiFi
Phone Idle
