no sd card
back up
Hi All
I have a ztpad andriod pad 12 inch, now i have paid to have apps added ( cracked ) now when using camera it was working ok but now says no sd card , the sd card is in pad , i have tried to remount the card but still nothing, even on xbmc navi-x has gone. anyone came across this please.
Hi back up, and welcome to AF :)
I'm not clear about what has been done to your pad. Have you had the ROM (system software) modified, and if so in what way? When you say something was "cracked" do you mean that you have had the system modified to give you administrator access (which is called "rooting" for android)? Or do you mean that you have had cracked apps installed (where the word "cracked" would suggest piracy, discussion of which is forbidden by the forum rules)?
Most importantly, is it just the camera that cannot see the sd card, or any application? You say that navi-x has gone (which if I understand right is an XBMC add-on), but do you mean the app has gone or it also can't see the sd card. And if nothing can access the card, does the card work in another device (i.e. is the problem the pad or the card)?
Finally, did the problem start when you had whatever modification it was made, or some time later?
Sorry to have questions rather than answers, but a clear description of the problem will help with identifying the solution.
Hi Hadron
I have completed a factory reset and still the android says insert sd card, it does recognise it in setting , the card works in other devices? could this be a hardware issue?
"It does recognise it in setting" is important: so the device can see the card? Can any apps see it (e.g. a file browser)? What does the device say about the card?
It could be hardware, but particularly if the device has been modified it could be software too. This is part of why I asked when it started.
