Root No signal after updating Kernel
burrito
I tried loading the New Revision 3 posted here:
http://androidforums.com/all-things-root-behold-2/53468-custom-behold-2-kernel-odin-ready-1-5-a.html
And now I get no service.
I tried doing a factory reset but it still didn't work. Then I tried an old revision of the kernel, and then a 1.6 kernel, but it still gets no signal. I went to the Network Settings and it said it couldn't find any networks.
Also, the phone takes a very long time to boot.
Does anybody have any tips?
switch everything back to 1.5 then whatever rom you are using might help
Thanks for the reply. I was using the stock 1.5 rom and I'm pretty sure I tried going back to 1.5.
In any case I just kept trying kernels and one FINALLY worked. It was the newest revision of the 1.6 kernel.
So now I can run apps that need root access, right?
if you are in 1.5 then why not switch to micro's 1.6. it is the ota that tmo released but without twiz and has root
I'm having the same problem and it seems like all the new ota (expect for the original) tweaks wont work on my phone anymore w/o root. HELP!
