Help No signal on Galxy Ace
My son in law has a similar phone to mine, its a Galaxy Ace, unfortunately his job is a plasterer and it had a lost of dust in the speaker phone slot on mini usb, I took it to bits and cleaned it put it back together and it seemed to work OK, after about an hr the signal strengh went to zero and cant make calls, I've checked the readings and his phone and its :
-113dBm 0 asu
mine is:
-83dBm 13 asu, could the antenna have been damaged when I stripped it down?
It had also been updated the day before but it was working after that.
Can anyone help?
Phil
-113dBm 0 asu
mine is:
Can anyone help?
Phil
haha, sounds like he needs a cheap & cheerful spare phone to wreck at work!!
have you tried it on 2G & 3G to see if it is just a network problem with your carrier? Go to "mobile networks" in settings & tick/untick the "use 2G" box.
Hope this helps, let us know! :) Graham
Hi Graham, thanks for the quick response, I've checked the mobile Network Settings, on my Son-in-laws phone they appear as follows:
1.Data Roaming
2.Use Packet Data
3.Access Point Names
No 2g networks text
4. Network Operators
In About Phone readings on Son in Laws
The version is 2.3.6
BaseBand S5830NEKT2
Kernal Version 2.6.35.7-perf-CL772922
root@Dell149#1
Build Number: GINGERBREAD.XWKT5
However on mine its
1.Use Packet Data (ticked)
2.Data Roaming (off)
4.Use only 2g networks (ticked)
5.Network Operators
In About Phone readings on mine
The version is 2.2.1.
BaseBand S5830XXKB1
Kernal Versiom2.6.32.9-perf
root@Dell104#1
Build Number: FROYO.XWKB7
My Galaxy works fine, not sure if son in laws had different settings before update.
I've tried the Sim Card from my phone and the phone signal is the same.
