Help No Sound on Videos
brightsn
When I try to transfer videos shot with my phone from the SD card to the computer, the vids will play with Windows Media Player, but there is no sound. Does anyone a fix for this?
TIA
TIA
download a video call Gspot (google it)
it will tell you what video and audio codecs are required to play the file.
check your file with GSPOT and then see if it has audio.
If it does have audio on GSPOT (but doesn't play,then you need to see what codec it uses and then download the codec or reinstall it to hear audio.)
try vlc player also, it plays almost everything (more than windows).
It might be that your windows player doesnt have the proper audio codec installed, or your computer might not have it either.
Edit: Here is the link so you dont get caught looking up bad results with G spot
http://www.headbands.com/gspot/
This link looks more like the one I use from the pictures (not dirty)
http://www.softpedia.com/get/Multimedia/Video/Encoders-Converter-DIVX-Related/GSpot.shtml
