Help No Sound!
bamachick
Hey guys,
I was listening to my mp3s this morning, and all of a sudden, my speaker cut out, and now there is no sound coming out of it at all. I've tried different apps (Pandora, etc.) and I've tried just the ringer, but nothing. Has anyone run into this and how can I fix it?
Thanks!
If you have no sound at all, I would backup my information ( contacts, apps, data, etc..)
Turn the phone off, and Power the phone into recovery mode (volume down & power together)
Wipe data factory reset
Test the phone's volume again, if still not working, you may have blown your speaker, or maybe have a hardware issue
You also may want to contact boost about a replacement
I had a problem with media starting and stopping, and no sound from youtube, although I had sound from ringtones, so I knew the physical speaker worked. After some research, I did a factory reset. No luck. I uninstalled all apps. No luck. So I did a 5 minute battery pull. No luck. Finally, I did an overnight battery pull = remove battery for 8 hours. Woke up, and assembled the battery to phone. My homescreen had 2 old icons that were right on right before I deleted the apps the night before. Maybe there is a buffer stack overflow in the droid deletion routine? (question for the devs). And so to continue, I started up my tunein radio and the sound and program work perfectly! Long story short, just try taking the battery out for 8 hours to fix your phone! ;-)
