no sound
  • Start date Start date
A
Android Question
Guest
HTC desire s no sound on alarms ringtone YouTube or anything not sure what to do checked all settings they are same as always
Hi, welcome to Android Forums, I'm sorry it's taken so long to get back to you.
I did a search and I think I came up with a solution.
the problems is not actually a bug or factory default but the way we remove the earphones from HTC after listening to music or Radio. We usually just pull it out.
Remember when you plug in you earphone you have to deactivate speakers for Earphone to work, (most especially for Radio). but when you just remove it without activating the internal speakers they remain deactivated.
I had this problem yesterday when my son pull off the earphone pin. I tried factory setting it did not work. but what I just did was to insert back earphone, de-active the earphone and my internal speakers just came back, loud and clear
one need to
I had a problem with media starting and stopping, and no sound from youtube, although I had sound from ringtones, so I knew the physical speaker worked. After some research, I did a factory reset. No luck. I uninstalled all apps. No luck. So I did a 5 minute battery pull. No luck. Finally, I did an overnight battery pull = remove battery for 8 hours. Woke up, and assembled the battery to phone. My homescreen had 2 old icons that were right on right before I deleted the apps the night before. Maybe there is a buffer stack overflow in the droid deletion routine? (question for the devs). And so to continue, I started up my tunein radio and the sound and program work perfectly! Long story short, just try taking the battery out for 8 hours to fix your phone! ;-)
