ian arkley
hi peeps i have a android tv box but no streams are working on anything films sports etc some pages just load up blank aswell . any ideas of whats happening ?
thanks ian
thanks ian
O wthis problems been going on for months now
Did you reset I can get that back fix the problems first. This is a MX you saymx on the box. and now i currently have no add ons everything seems to have been wiped
Use xbmc kodi I think is better did u reset and now Dont have net connection or explorer never workedxmbc is working just got no programs now and for some reason i cant get a internet explorer on it :s ....... dont no if it helps but i have managed to get xmbc and gotham on my laptop is there a way i could transfer it over ?
really appreciate the help thanks
Your speaking a confused language I am lost you want to transfer it to the MX box . now can I ask will this download to the box or not if your looking to keep the addon just add what you have or get the newest ones. This maybe why it shut down . you didn't update the addon . it should also be a add on for updates. But transfer a xbmc app and add on I Dont see or never heard of that . not saying it can't be done but I never did or done it. I just do the addons and notice new ones .so does that mean i cant transfer it ?
