Help No UI when on A/C power
jimmy4vb
I've had my Mesmerize since Nov 2010 and had it upgraded to stock 2.2 in the store. The phone was stellar running 2.1 but has been a headache running 2.2 (bluetooth issues, unlock issues, missed calls, flaky signal strength, no UI when powered, softer vibrate, etc.). I did a factory reset and then upgraded to 2.2.1 (EE19) via mini kies at home. The update fixed the missed calls issue, so it is actually a phone again. The other problems are annoyances, but the one that continues to confound me is the non-functioning UI when on A/C power.
I use streaming audio while at work and need to keep the phone A/C powered. When powered, the touchscreen UI is unresponsive or erratic about 80% of the time. Unplugging the power fixes this 100% of the time. USCC's tech support recommends I do a complete reflash but I have been reluctant to do so.
Anyone else see this problem? Any suggestions outside of a reflash?
I agree with the reflash. For whatever reason, the mini kies updates seem to cause more problems than they solve.
I have only noticed that issue with mine when I don't use the samsung supplied power cord/adapter.
If I use a generic power cord I will have a nonfunctioning touch-screen till I unplug it. It will charge, and receive calls and such, I just can't do anything with it till I unplug it.
If I use the stock cord I can use it like it's not plugged in at all.
