Help No vibrate on text message help!
Same happend to me lol u have to go into the text app and press Menu To go to settings, scroll down to notification settings n click vibrate n set it to always. Make sure u set ur Phn ON VIBRATE FIRST. Then click always
Yes try to put your phone into the vibration mode and then try, if not resolved then reset to factory settings which is in ur settings.
