No Vibration on Key Press in Phone Dialer?
Does anyone know how to turn on the Vibration on key press on the dialer itself? I can turn on/off touch tones, but no feedback/vibrate on key press on the dialer pad.
Also, does anyone know what Battery Saver actually does? I see nothing on it anywhere.....
Thanks!
Thanks!
That's strange. When I press digits in my dialer I get a short pulse/vibration. I don't remember turning it on anywhere. When I just checked, I don't even see it as an option.
Battery saver kicks in at 15%. It shuts down the refresh rate of some apps and others off completely. It takes over brightness and other things to stretch your battery. I'm not sure how much battery life it adds, but that's what it does when it gets there.
My phone vibrates on the dialer keypad. Do you have "settings->sound->vibrate" on touch turned on?
Thanks so much for the info. I appreciate it!
