Help No Voicemail Alerts
Hello, I just upgraded my Droid 1 to a Droid 2 Global...for some reason I can't seem to get a notification/alert whenever I receive a new voicemail. I don't have visual voicemail...but regardless, there is no alert when I get voicemail...does anyone know how to activate this?
Thanks!
Some users report having notification issues if Google Voice is enabled. The remedy in those cases is, obviously ;), to turn off GV.
If that is not your situation, I'd double check my menu settings to be sure I have notifications for VM enabled in sounds and display.
Thanks Frisco! I actually called up Verizon and it turns out, I had visual voicemail enabled (which I never did)...so they needed to shut it off, and then the notifications started coming in! :)
