hanskedrie
Hi everyone,
I just bought a samsung galaxy apollo i5801.
When I want to connect to wifi via my router I can't get connected.
The first time I had no mac address so I did a hard reset. After that I could see the mac address and I could scan for wifi. I also found my router. I clicked it to connect (and entered the correct password). After that I can't get any internet connection on the phone (the wifi icon doesn't appear on the screen). If I go back to the wifi setup I see that the wifi connection is canceled.
I did another hard reset, but the problem stays the same.
Also via a static IP-address it wont work.
I cannot enter the mac address from the phone in my router because then I get the error that it is in the wrong format (it has to start with a 0).
Does anyone know what this problem is caused by?
Also I see the GPS is on but there is no icon in the top screen (where I tought there should be an icon, just like with the wifi).
If nobody knows a solution I will be going back to the shop on monday because I have a slight feeling there is something wrong with the phone.
The following software is on the phone: Firmware version 2.1 update - 1 Eclair.
I tried to connect to my computer with Kies as well and then it says that it cannot update the phone.
Hope someone can help me in the right direction.
Kind regards.
Kind regards.
