I've been having sluggish Data connections and I'm aware of metro " Fixing there data,and making 3g better" -___- but no connection at all for sometimes over an hour is how I'd say " No Bueno"!
Anywho apparently this only happens when I'm on Simple IP. So I switched back to Mob ip and data is perfect. But now when I run wifi tethering, the message on my laptop comes up from Metro. Even after changing "true" to "false" in my build.prop. I've come to think it may be something in our build.prop settings? Maybe?
Anywho, any opinions or ways to fix are welcomed. Please stay ON TOPIC! If you have a question of your own just make another thread.
EDIT: 3/30/12 - Well I couldn't find or fix the issue with the Mob ip issue but I did fix my issue with the sluggish data connections on Simple ip. Thanks to nekogarushia for these instructions here.
"Using QPST
Hit Read from phone put your SPC
1- Go to M.IP tab and select profile 0 and edit your user name remove the "aaak." just for the first row. Should be (yournumber@mymetropcs.com)
then change the mobile ip behavior to: simple IP only
2- Go to PPP Config - and choose Um, change the user name (Your Phone#@mymetropcs.com) the password is your SPC
3- Go to PPP Config- and choose AN, change the user name (Your Phone#@mymetropcs.com) the password is your SPC
4 -Write to Phone (wait for phone to restart)
wait a few mins and your 1X/3G should be back!
Thanks for this guide http://androidforums.com/samsung-admire/454073-regarding-2-3-6-update-metropcs-solved.html I fixed my no data issue (Yes this is for 2.3.6 but it fixes the issue of 2.3.4)"
"Using QPST
